Jonatba
Oct 17, 2023Aspirant
Netgear WNDA 3100v2 can't find MY internet, but can find my neighbours's
My wifi adapter has worked fine until last week where my own network dissapeared from the network menu. i can connect to it with my phone and other devices but not my pc. i can see my neighbours's ne...
michaelkenward
Oct 18, 2023Guru - Experienced User
Is your network visible on other wifi clients?
Connect to what with your phone? Your network?
i can see my neighbours's networks.
Is that from the USB adapter and a Windows PC?
If it just just the PC that can't see the local wifi, then this could be something happening in Windows. That's probably where to troubleshoot rather than the Netgear adapter.
In Windows 11 look here:
- JonatbaOct 18, 2023Aspirant
Thank you for the reply!
Yes, it is visible on all my other devices.
yes, my network is visable and usable on both my phone and laptop
yes
i've tried troubleshooting on my pc and it couldnt find anything, i use windows 10. i don't think the problem is windows, because I tried to connect to my network with a different adapter i borrowed. and that worked.
- michaelkenwardOct 18, 2023Guru - Experienced User
That's detail that was not in your first message.
But that misses the point. If Windows accepts one adapter and not another adapter, then that may mean that Windows just doesn't like the WNDA3100v2.
That is an old adapter that predates Windows 10 and 11. You could try the trick that worked for another recent victim of USB issues.
Re: A6210 Constant Disconnecting - NETGEAR Communities
Uninstall the WNDA3100v2 and then just plug it in and see if Windows finds and install its own drivers.
In your shoes I would forget about the WNDA3100 devices. They date back to 2007. Even the V2 is from 2009. Wifi technology has come a long way since then.
Thank you so much for the help, I'll try you suggestion as soon as i get home. Hoping i dont need to buy a new adapter:)
