ftgml
Jun 22, 2022Follower
Netgear WNDA3100v2 no longer connect to Wifi network
The old Netgear WNDA3100 v2 USB Wifi adapter used to be able to connect to both 2.4Ghz and 5G FIOS wifi. However, it no longer doe that. The only time it recognizes the 2.4 home network is when it is...
Jun 22, 2022Guru - Experienced User
have you tried it on a different device?
