danipana
Aug 23, 2019Aspirant
netgear wnda3100v3 does not connect anymore
After vacation my wifi adapter stopped working. In genie it gives me the correct list of networks but after I enter the password it gives me the error that it is not able to connect to the network. ...
Marie-LouisedJ
Aug 30, 2019Aspirant
I have the same problem after windows 10 Home update 1903. Problem is wnda3100v3.sys: that causes a BSOD.
- michaelkenwardSep 09, 2019Guru - Experienced User
The WNDA3100v3 is an old, 2014, wifi adapter based on an even older 2007 device.
Maybe Microsoft has just decided to kill it off.
One thing to try would be to unplug the adapter, remove all Netgear software and drivers, and then plug the device back in to see if Windows will use its own native drivers.
