perseid
Oct 26, 2023Aspirant
Nighthawk A7000 AC1900 with iPad Pro
Has anyone been able to use the Nighthawk A7000 AC1900 WiFi USB Adapter with the iPad Pro? I connected the Nighthawk to the iPad's USB C port but it is not showing under Settings/Wifi. Is there a tri...
perseid
Oct 27, 2023Aspirant
iPads run iPadOS which is mostly iOS for the tablet. The iPad's internal antenna is not very good at picking up weak signals, it would be strongly boosted by being able to use an external USB antenna like the AC1900.
michaelkenward
Oct 28, 2023Guru - Experienced User
You probably need a USB adapter designed for that purpose.
Netgear seems to be useless at making Apple specific devices, probably not helped by Apple's aversion to anything that it does not make and sell. Even when Netgear does make something, it dies as soon as Apple pushes out an update.
- perseidOct 29, 2023Aspirant
Unless of course Apple closes a deal with Netgear for a specific accesory. That's why I spoke of a "hack" as I know that using 3rd party accesories with Apple products is not possible in most cases.
