RichieIsHuman
May 13, 2021Follower
Nighthawk A7000 Adapter Unstable Connection
This only just recently started happening so I'd assume it would be fixable, but no one has an answer for it. Just recently, my WiFi USB Adapter has been unable to keep a strong connection to my wifi...
michaelkenward
May 14, 2021Guru - Experienced User
RichieIsHuman wrote:
(p.s. I know its the adapter because no other devices in the house share this problem)
I would not jump to that conclusion. It could be your operating system (Windows?) or your router.
Wifi is a two-way process. The adapter talks to the router. Windows sits in between them.
Have you looked for local wifi interference?
Have you tried different wifi channels?
Is this on 2.4 GHz or 5 GHz.
