Proxee0
Dec 25, 2020Aspirant
Nighthawk A7000 USB 3.0 Adapter not connecting Xfinity
I recently moved and have a 1gb connection setup at my new place with Xfinity. I purchased an A7000 wifi Adapter to take advantage of my new internet speeds. Before I bought the A7000 I was using...
michaelkenward
Dec 25, 2020Guru - Experienced User
Proxee0 wrote:
Problem with this is when I am connected with my Edimax AC600 this option shows on my Properties for my Internet Connection. HOWEVER, when I have my A7000 connected, this option to set it to a Private network is not available.
Where are you looking?
- Network and Internet settings
- (Network) Status
- (Change Connection) Properties
- Network profile
- Private
If it isn't there, maybe something is odd in your network settings.
Have you tried the Windows network troubleshooter?
What do you see here?
- Control Panel
- Network Connections
- Wifi device
Proxee0
I'm not sure why my Image didn't upload. Basically what I sent was on my Edimax when I go to Network Connections and I check my Properties it will allow my to change the Network Profile. When I go to this same place when my A7000 is connected, it shows no Network Profile.
When I do the Windows Troubleshooter on my internet connection it will say "No Valid IP Configuration."
michaelkenward wrote:
Proxee0 wrote:Problem with this is when I am connected with my Edimax AC600 this option shows on my Properties for my Internet Connection. HOWEVER, when I have my A7000 connected, this option to set it to a Private network is not available.
- (Network) Status
- Network profile
- Private
- Control Panel
- Wifi device
- michaelkenwardDec 25, 2020Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
