TEXASCITIZEN
Dec 15, 2022Aspirant
Nighthawk A7000 wireless adapter & Genie/ Nighthawk app
**The issue is Downloading Nighthawk Genie or its successor for PC. I have a Nighthawk wireless adapter (A7000) which I have been using for 2-3 years with Win 10 on my desktop. I bought a new Dell ...
- Dec 15, 2022
download the file from netgear from here:
https://www.netgear.com/support/product/A7000.aspx
then extract it. If its windows, just right click on the file and use windows by right clicking on it and going to extract all.
From there install the stand alone driver. You don't need the built in netgear utilities. let windows handle it
Dec 15, 2022Guru - Experienced User
- TEXASCITIZENDec 16, 2022Aspirant
Plemans--thanks for responding. Just a few minutes ago I had stumbled into a similar solution to yours when, while looking though my new PC I found the original download for the Genie. (My original installation Nighthawk disk had stopped reading--when I would put it in the reader the light would flash 3 times & then go dead but I could watch movies off a CD so the reader was good.)
The download had an autorun line. When I clicked on autorun it asked for a disk; I put the original disk in & it started to read. Within a few minutes I had the original Genie icon back on the desktop & it works.
