NG_012264
Dec 08, 2020Follower
Nighthawk AC1900 WiFi USB Adapter – Won't connect?
System: Win 10 new install To make a long story short – I'm able to install the drivers and they work fine. I'm able to use either the Gene app download or the standalone download – they both work t...
Dec 08, 2020Guru - Experienced User
You're exactly correct in trying it somewhere else first to see if its a router issue.
it wouldn't be the first time.
Also check if the windows versions are the same. I've seen issues with windows causing issues before.
