SpecialToast
Dec 28, 2021Aspirant
NightHawk AC1900 Wifi USB Adapter USB 3.0, Dual Band having connection problems?
I currently own a NightHawk AC1900 Wifi USB Adapter 3.0, Dual Band that I've been using for a while and decided to test out the performance of it via Speed Test. My Ping was 12, Download: 206.43Mbps,...
michaelkenward
Dec 29, 2021Guru - Experienced User
And the router you use is?
- SpecialToastDec 29, 2021Aspirant
We have a Linksys EA7300 wireless router that's connected to a XFINITY XB6-t Modem. I did attempted to uninstall and reinstall the driver which seemed to fixed the problem so now it's back showing as 5GHz but I'm not quite sure why after plugging my computer to the router via ethernet had changed it the other day?
