Sllmilehi
Mar 05, 2023Follower
Nighthawk AC1900 WiFi USB Adapter
I have a new (refurbished) computer and want to use this Wifi Adapter to connect to existing WiFi network. SINCE I can't boot my computer without it looking for internet, can I use this (relatively e...
Mar 06, 2023Guru - Experienced User
I'm a bit confused.
Is this a windows pc?
What adapter are you talking about? AC1900 is a speed, not a model.
Also, why won't your pc boot without an ethernet connection?
- michaelkenwardMar 07, 2023Guru - Experienced User
Probably the A7000. The only USB adapter I can find with AC1900. Dates from around 2017.
