Caravanken's avatar
Caravanken
Follower
Nov 17, 2020
No internet
Netgear 56 router for home network works fine. Internet (wireless and Cat 5) started dropping and could be brought back with a power cycle. Now internet does not come up at all. All router status lights are blue except internet and it is amber. I have Cox Cable and they have cycled my cable modem and I have done a power reset and a reset buttonon the modem - no help.  I have cycled the NG 56 router via power and reset button several times and still no internet.  I have installed my old Netgear 44 router and internet works. I moved the WEB Cat 5 cable from the NG 44 to the 56 and the internet did not come up. Everytime I plugged the WEB Cat 5 cable into the NG 44 I had internet and in the NG 56 I do not.  I have spent in excess of 3 hours on Tech support with no luck at getting a solution. The hold times are completly unacceptable.  I know the end results will be a new router but getting there seems to be a challenge.
1 Reply
  • plemans's avatar
    Netgear56 is your ssid name. Not your model.
    What model router do you have? (look at the label)
    What firmware is on it?
    What modem do you have from cox?
