blueone
Nov 20, 2016Aspirant
Older Netgear wireless adapter
I'm trying to get my older Netgear wireless adapter to be compatible with windows 7 if possible. It's a ma111v2 802.11b/n/g
TheEther
Nov 20, 2016Guru
The MA111v2 is ancient. It only supports 802.11b, not 802.11b/n/g. Its fastest link speed is 11 Mbps. You'll get, at best, 5 Mbps out of it. It's unlikely that the drivers will work on Windows 7. Save yourself the trouble and buy a new adapter.
- blueoneNov 20, 2016Aspirant
Yeah, I knew it was pretty old but thought I'd give it a try before buying a new one that probably won't work. :>)
