om_p
Feb 25, 2021Aspirant
random lag spikes with my a6210
hello i am expierencing constant lag spikes whenever I play games. I have tried everything I can think of, updating the driver, changing settings etc. i need help thank you
Feb 26, 2021Guru - Experienced User
what router are you using?
om_p
Feb 26, 2021Aspirant
- plemansFeb 26, 2021Guru - Experienced User
photos take a while to be approved by a moderator.
What actual router model is it?
did you read the article? There's certain things you can done to improving ping/lag spikes on wireless.
- om_pFeb 26, 2021Aspirant
the model name is xb7, and i am sure that it is not the routers problem because wegot the adapter with the router, I think the problem is with the adapter.
