callwill
May 02, 2021Aspirant
a7000 on W10 desktop- keeps resetting itself to automatically connect- and a "new" hidden network"
A7000 usb 3.0 Adapter on W10 Desktop- driver from netgear site. WNDR 3700 Router. I have had minimal trouble with my netgear equipment since my first and only router(2009?), the WNDR 3700 that pro...
michaelkenward
May 10, 2021Guru - Experienced User
callwill wrote:
I have been thru every windows setting i can find and cannot find anything to change the behavior i am experiencing.
My guess is that there is a setting somewhere that you have not found. I have never seen this behaviour. If anything I have to work hard to get the PC to connect.
We don't know where you have looked for the right setting. You say you went thbrough the "all the places listed". There was just one place with instructions on how to get there. Maybe I should have used a better format.
Did you find this?
Th hidden bit is my local wifi's SSID.
callwill
May 10, 2021Aspirant
Yes. Despite your stating "one place to look", i took that as a list to follow up on possible leads to somthing in my seach for some thing to change... Been there and any related setting i can find.
- michaelkenwardMay 10, 2021Guru - Experienced User
I did day one place to look. Would this have been clearer?
>> Network & Internet >> Wifi >> Manage Known Networks >> Pick your SSID >> Properties >> Connect automatically when in range
You did say you had looked all over the pace. I assumed that you knew what you were doing.
You didn't say if you arrived at the screen I posted.
Remember, this is done for the SSID, not the adapter.
- callwillMay 10, 2021Aspirant
You asked..."Did you find this?"
I responded... "Yes."... "Been there and any related setting i can find."
I probably could have been a bit more definitive.
Your problem is with Windows.
Netgear's USB devices have no control over this feature.
