Apota4U
Apr 29, 2019Tutor
A7000 USB Adaptor Constantly Disconects.
I have a A7000 USB 3.0 Wifi adapter that worked fine for a couple of weeks and now it constantly disconnects and to get it to reconnect I have to unplug it from the USB port on the back of my compute...
Apota4U
Apr 30, 2019Tutor
I found the post here but I'm not sure if my issue is the same one.
I am having the same problem. This odd adapter is coupled with Netgear's R7000P (AC2300) router. To disable "RunSwUSB", double click the offending service and you will have the option to permanately disable the service. Simply select "Disabled" as the Startup type.
Model: A7000|NIGHTHAWK AC1900 WIFI USB Adapter
Message 7 of 9
Streak2
May 25, 2019Master
I just built a new PC and I am using the A7000.
Same as others have reported, every couple of hours the A7000 would just disconnect and then reconnect from the PC with the usual USB disconnect ding dong sound.
I have just disabled RunSwUSB and will see over the next few days if that fixes the issue.
