VladislavV87's avatar
VladislavV87
Re: Device undetected after computer wakeup
Same issue here. I bought it over a month ago, and every time I wake my computer, there's no internet, and it gives a code that the device couldn't start. The only solution is restart, which defeats the purpose of the sleep function on Windows 10.
  • VladislavV87's avatar
    VladislavV87
    Feb 16, 2025
    I fixed it by disabling low energy mode in the Device Manager settings. The original post had that step there too. I didn't read it carefully enough.
    I appreciate your response.
  • michaelkenward's avatar
    michaelkenward
    You have joined in on the end of a conversation that ended seven years ago and that may or may not have anything to do with your problems.
    There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
    If you do want help with your problem, check previous stuff that may be related then start your own discussion.
    If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
    Restart what? The PC? How about the USB settings for yhe adapter in Windows?
    Disclaimer: Just another user with time on their hands.
      VladislavV87
