Mekroval
Jan 26, 2020Follower
SOLVED: Constant Disconnection of Netgear A6210 Adapter
I wanted to share a solution to a reoccuring problem with my A6210 Wifi Adapter that seemed to be causing a problem for a lot of other people as well. Many of the threads on this support community of...
fire_kid2003
May 30, 2020Aspirant
HI
where have you changed the value "Max USB Speed value from "USB Auto" to "USB 3.0" ?
on windows 10
leeR17
Aug 21, 2020Initiate
Hi, I had the same problem for months here is how to change the USB Max value as suggested as a solution:-
1. Go to device manager
2. Expand "Network Adapters"
3. Double Click "NETGEAR A2610 WiFi USB3.0 Adapter"
4. Click Advanced Tab
5. Click Max USB Speed
6. Change Value on right from USB Auto to USB 3.0
