ken-spress
Sep 27, 2020Follower
Speed Issues Netgear A7000
I have a netgear a7000 wifi adapter and I have had it for quite some time. I notice that when I use it for speed tests and downloads and such that any speed over 250 mbps I get about half speed. ...
michaelkenward
Sep 28, 2020Guru - Experienced User
ken-spress wrote:
Ask me questions you may have.. but it seems kind of weird that on wireless I can't reach more than 250 mpbs
Wifi speeds rarely achieve wired speeds, especially with fast Internet. The bottleneck is the wifi client. For many wifi clients, 250 Mbps is as fast as you will get. Some are even slower than that.
Think of it like this, if you take a clapped out 25-year old car to a Formula 1 racing track it will not magically keep up with Lewis Hamilton's Mercedes. It is the car that matters, not the racetrack.
Can you get better speeds with different wifi sources?
Here's a website that goes into the issue in excruciating detail:
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
duckware is a great source of sensible information on wifi.
Then there is this:
Why am I not getting the maximum speed that my router is capable of? | Answer | NETGEAR Support
It is old but the message is still valid.
The only way to get a reliable test of the speed of the Internet on your router is to have a wired connection into a LAN ports. Even there you may find that different websites will deliver different speed results. (I usually check on half a dozen.) And it can change during the day depending on the traffic.
