FaridMono
Sep 22, 2020Aspirant
Support for A7000
I have recently been having issues with connections dropping in and out with my home internet perfectly fine. I have downloaded the Netgear Genie software and updated the firmware with no improvement...
FaridMono
Sep 28, 2020Aspirant
So what more information do you need? I can let you know.
Because this adapter just keeps disconnecting randomly with no actual issues with our home internet services. I have looked online and there are a lot of people experiencing the same problems. I have gone through all the fixes that other people have suggested like disabling Runswusb etc but still getting disconnected randomly. The Tech support guys says its not a hardware issue so I don't know what it is.
Please do tell me what more info you need from me other than the core issue of the adapter disconnecting randomly all the time.
Kind regards,
Farid
michaelkenward
Sep 28, 2020Guru - Experienced User
Your first message was a long(ish) account of your dealings with Netgear support, none of which is relevant to fixing your problem.
All that we know about that problem is that you were "having issues with connections dropping in and out".
That said nothing about any pattern there might have been or what you had tried to fix it.
Here is a similar discussion where the person who asked for help described their situation in a little more detail:
A7000 Nighthawk consistent drops, ping spikes - NETGEAR Communities
You say you have tried everything you can find. I assume that it included the suggestions made there.
- FaridMonoSep 30, 2020Aspirant
Well yes. My long-ish accounts of my dealings with the tech support was one of the problems. They did not want to help unless I paid them which I find is ludicrous.
But back to the main problem at hand. What was suggested as a solution to ensure that Windows isn't set to turn it off in device manager is something that is a common solution for everyone it seems. I did this already. It stopped the REGULAR random disconnections but it still disconnects randomly. Just more inconssistenly.
So is there anything else that I can do?- FaridMonoOct 08, 2020Aspirant
So what is the solution?
