Jatins
May 20, 2022Follower
Support window 10
I have WG111V3 wireless adapter is this adapter supporrt window 10 pro 64 bit After connect it showing driver not available. Please help
Osgboy
Nov 09, 2024Aspirant
Hey, this worked for me:
- Go to https://catalog.update.microsoft.com/Search.aspx?q=wn111v2
- Download whichever latest version of "Atheros Communications Inc. - Network - RangeMax Wireless-N USB Adapter WN111v2" works for you (I downloaded the AMD64 version)
- You should've downloaded a .cab file
- Open command prompt and type the following:
- expand <CAB FILE NAME> -F:* <DESTINATION>
- You should see 3 files: arusb_lxh.sys, arusb_lhx.inf, and arusb_lhx.cat
- Right click arusb_lhx.inf and click install
