Guiikcar
Dec 25, 2024Aspirant
Title: NETGEAR A7000/AC1900 Issues on Windows 11 – Network Adapter Not Working Properly
Hi everyone, I’m encountering a frustrating issue with my NETGEAR A7000/AC1900 WiFi USB adapter on my Windows 11 PC. Here’s what’s happening: If I connect the adapter and reboot, Windows 11 f...
- Dec 27, 2024
Hi, sorry for the long reply. I recently performed a Windows update, and it seems like the issue is now resolved—I’m no longer experiencing any problems with the adapter. Thank you so much for taking the time to help me, I really appreciate it!
michaelkenward
Dec 26, 2024Guru - Experienced User
Guiikcar wrote:
Has anyone else experienced this or found a solution?
Did you find this?
Solved: Re: A7000 / AC1900 NightHawk Extender No longer co... - NETGEAR Communities
One of a bunch of messages, some of them Solved, about issues with the A7000 and Windows.
Check the Recommendations bit at the bottom of these messages.
Just another user with time on their hands.
- GuiikcarDec 26, 2024Aspirant
Hi, thank you for your response.
The issue you described doesn't seem to match my situation exactly. I can connect to a WiFi network without any problems (I’m actually using it to write this message). However, the suggested solution of resetting the computer feels a bit extreme.
Since I use my PC for work and have a lot of important data and software installed, resetting it would take a significant amount of time and effort to set everything back up again.
Do you think resetting the computer is the only solution, or is there another way to fix this issue?
Thank you in advance for your help!
- plemansDec 26, 2024Guru - Experienced User
what version of windows (24h2, 23h2, etc) are you on?
Have you tried other USB ports or trying a hub on bootup?
- GuiikcarDec 27, 2024Aspirant
