Guiikcar
Dec 25, 2024Aspirant
Title: NETGEAR A7000/AC1900 Issues on Windows 11 – Network Adapter Not Working Properly
Hi everyone, I’m encountering a frustrating issue with my NETGEAR A7000/AC1900 WiFi USB adapter on my Windows 11 PC. Here’s what’s happening: If I connect the adapter and reboot, Windows 11 f...
- Dec 27, 2024
Hi, sorry for the long reply. I recently performed a Windows update, and it seems like the issue is now resolved—I’m no longer experiencing any problems with the adapter. Thank you so much for taking the time to help me, I really appreciate it!
Dec 26, 2024Guru - Experienced User
what version of windows (24h2, 23h2, etc) are you on?
Have you tried other USB ports or trying a hub on bootup?
Guiikcar
Dec 27, 2024Aspirant
- michaelkenwardDec 27, 2024Guru - Experienced User
There's Windows for you. Sent to try us all.
Just another user with time on their hands.
