Alan_123
Aug 19, 2020Aspirant
Trying to use a USB scanner by wireless... No USB cable... Win 10 environment...
Hi... Hope I have a very easy question... I have a new Dell i7 Win 10 laptop and I need to connect a USB scanner to it. Normally, the scanner would use a USB 2.0 cable to make the connection, but I d...
- Aug 23, 2020
Respectfully, "impossible" is inaccurate... USB is just a transfer protocol (pretty simple too...) As I mentioned, I do have a wifi network... I just checked, and my first floor machine easily talks with one of my second floor machines, including a scanner. All I need to do is hook up my new scanner into one of my network machines (I think I'll buy a dedicated machine), and wifi and Windows will take care of the rest... Easy breezy...
Alan
A.S. Microprocessor Technology
B.S. Computer Engineering and Electrical Engineering
P.S. Have you ever written a driver or dll? I have...
michaelkenward
Aug 23, 2020Guru - Experienced User
Are you asking for a router that you can plug the scanmer into?
Alan_123 wrote:
The scanner is not equipped to handle wireless...
Won't work. Printers yes, but scanners no.
Did you post in the powerline section for any reason? Or was it a random choice?
If your scanner does Ethernet, powerline might work.
- Alan_123Aug 23, 2020Aspirant
Hi,
I don't know if I need a router or not... I don't see why USB wireless can't work with scanners... In fact, I have a wireless scanner/printer/fax that works with both USB or wireless, and that works fine as a wireless USB scanner. Beyond that, wireless has been around since 2010 (look up WUSB). Iogear used to make a standard wireless dongle, but they no longer make it... There must be some manufacturer out there that makes such a thing...
- michaelkenwardAug 23, 2020Guru - Experienced User
Do some research then. It ain't gonna happen.
If you want to use a plug-in USB adapter to connect something like a scanner to your wifi, forget it.
USB adapters depend on drivers and things. These need an operating system. Sadly, your scanner cannot run an operating system. Netgear's adapters won't even work on Unix systems, and only some will connect with Macs.
People ask about using a USB adapter to connect various things, especially TVs. It won't work.
If you want to confirm this, just ask the people who made your scanner. They know what will work with their hardware.
Alan
- Alan_123Aug 25, 2020Aspirant
Hi all,
This is exactly the type of product I was looking for... https://www.amazon.com/Belkin-Certified-Wireless-Adapter-F5U302/dp/B000UYWTWS#:~:text=%20Belkin%20Certified%20Wireless%20USB%204-Port%20Hub%20with,linking%20high-%2C%20full-%2C%20and%20low-speed%20devices%20More%20
Heads up... Searching on: "certified wireless USB" and "DWA" and "HWA" is enlightning... Now I just have to find a current version... Thanks all...
