Alan_123
Aug 19, 2020Aspirant
Trying to use a USB scanner by wireless... No USB cable... Win 10 environment...
Hi... Hope I have a very easy question... I have a new Dell i7 Win 10 laptop and I need to connect a USB scanner to it. Normally, the scanner would use a USB 2.0 cable to make the connection, but I d...
- Aug 23, 2020
Respectfully, "impossible" is inaccurate... USB is just a transfer protocol (pretty simple too...) As I mentioned, I do have a wifi network... I just checked, and my first floor machine easily talks with one of my second floor machines, including a scanner. All I need to do is hook up my new scanner into one of my network machines (I think I'll buy a dedicated machine), and wifi and Windows will take care of the rest... Easy breezy...
Alan
A.S. Microprocessor Technology
B.S. Computer Engineering and Electrical Engineering
P.S. Have you ever written a driver or dll? I have...
michaelkenward
Aug 23, 2020Guru - Experienced User
Are you asking for a router that you can plug the scanmer into?
Alan_123 wrote:
The scanner is not equipped to handle wireless...
Won't work. Printers yes, but scanners no.
Did you post in the powerline section for any reason? Or was it a random choice?
If your scanner does Ethernet, powerline might work.
Alan_123
Aug 25, 2020Aspirant
Hi all,
This is exactly the type of product I was looking for... https://www.amazon.com/Belkin-Certified-Wireless-Adapter-F5U302/dp/B000UYWTWS#:~:text=%20Belkin%20Certified%20Wireless%20USB%204-Port%20Hub%20with,linking%20high-%2C%20full-%2C%20and%20low-speed%20devices%20More%20
Heads up... Searching on: "certified wireless USB" and "DWA" and "HWA" is enlightning... Now I just have to find a current version... Thanks all...
