clydebrownjr
May 11, 2023Aspirant
unable to change open wifi connection to secure
Have used settings to change to wpa-2 as well as password on a old windows 10 machine. installed using install genni. I am happy with the speed but living in an apartment every broke ass tenants wil...
clydebrownjr
May 12, 2023Aspirant
I am trying to install from cd. The program searches for all available connections repeatedly Finds them and then repeats the process as in a infinite loop. It will not complete the installation. when I have to end the app from task manager. I click the wifi symbol from the task bar and find my connection click it and it works.
PROBLEM- the connection is "open" and when I try to correct it to "secure" from settings the information disappears. and reverts back to "open".
clydebrownjr
im trying to install the wifi dongle A7000 on an old DELL COMPUTER WITH NO FACTORY INSTALLED WIFI
- FURRYe38May 12, 2023Guru - Experienced User
Try installing from a updated driver download?
