clydebrownjr
May 11, 2023Aspirant
unable to change open wifi connection to secure
Have used settings to change to wpa-2 as well as password on a old windows 10 machine. installed using install genni. I am happy with the speed but living in an apartment every broke ass tenants wil...
clydebrownjr
May 12, 2023Aspirant
I thank you for your input. !st i had to install from the cd because My computer had no internet access hence the purchase of A7000.. I was able to get it working well enough to download installation from the web. The same problem persists.
After the setup app asks for the connection and I respond, the discovery process takes place. all of the available connections are listed but it fails to connect. this process repeats itself infinitely.
I end the process from task manager and simply select the connection I desire from the list in my taskbar. This gives me a connection. But it is unsecured "open". I can use it but obviously this is unacceptable.
Upon reboot this process begins again and I'm back in the infinite loop. I guess what I need to know is how do I get setup to finish setting up. or a method to manually set it up.
michaelkenward
May 12, 2023Guru - Experienced User
Download to another device and transfer to a USB stick that will work on the PC. Even a mobile phone can do that.
What is the operating system on this old Dell PC?
I still don't know what that means. Where are you reading something that says "open"?
Where does this wifi come from? If it is from a public network system there's not much that you can do at the receiving end. That is down to whoever manages the wifi source.
