DannyS22
Jul 26, 2022Guide
Unable to update AC1200 USB Adapter Software
Just installed the AC1200 USB WiFi adapter and when trying to check for software dates thru the Netgear Genie I get the following message The software was what was on the disk with the adapte...
- Jul 27, 2022
A6210 that was - current downloads https://www.netgear.com/support/product/A6210.aspx#download
https://kb.netgear.com/000058840/A6210-Software-Version-1-0-0-39 contains two different kits
- If you want to install the adapter drivers including the NETGEAR utility (genie), run A6210_V1.0.0.39.exe and follow the on-screen install instructions.
- If you want to install just the adapter drivers without the NETGEAR utility, run A6210-Standalone_V1.0.0.39.exe and follow the on-screen install instructions.
To avoid issues on decent Windows systems, it's stronlgy suggested not to install the utility crap and strictly stick with the standalone driver install, and use Windows 10/11 for the adpater config.
DannyS22
Jul 27, 2022Guide
Sorry, it is a A6210 usb adapter.
Thanks for the reply. Hope this clarifies my type/
Danny
schumaku
Jul 27, 2022Guru - Experienced User
