Larry_G's avatar
Larry_G
Tutor
Dec 16, 2017
Uninstall WNDA3100V2
Replaced the WNDA3100 adapter with an A6100.  The A6100 works great.  I just can't uninstall the WNDA3100 function.  I get repeatitive error messages: cannot find SETUP.RTF.  There is a setup.ini in ...
  • Larry_G's avatar
    Larry_G
    Dec 25, 2017
    Thanks.  The reinstall and uninstall worked.
