JC5000
Mar 31, 2020Aspirant
Unlocked 4G LTE wifi modem/router that accepts a SIM card
I would like to set up a home network with access to the internet via cell phone provider network. My provider said that I would need an unlocked device that accepts a SIM card to be used on a 4G LTE...
michaelkenward
Apr 01, 2020Guru - Experienced User
Start here:
Mobile Broadband | Home | NETGEAR
If you need more help, try the appropriate section:
Mobile Routers, Hotspots & Modems
JC5000
Apr 01, 2020Aspirant
Thanks for pointing me in the direction of the LTE modems. I looked at the Netgear LB2120 Modem. If I interpret this correctly, I can connect to it directly through the LAN port or I must purchase some other device to provide WiFi, which is what I need. I have a Netgear ADSL Model 7550 modem/router that I currently use. However, the goal is to eliminate the DSL service and use the wireless to connect to the internet. Is there a mechanism to connect the LB2120 to the Model 7550 and use the router and WiFi capabilities of the 7550 without the DSL service? The 7550 only has 4 LAN ports and a port for the DSL cable. If the 7550 is not compatible, what is the other device that must be purchased? Are there any 4G LTE modem/router/WiFi devices?
- michaelkenwardApr 01, 2020Guru - Experienced User
Netgear may have made it, but the 7550 is specific to AT&T.
No NETGEAR support for the AT&T 7550 DSL Modem Router | Answer | NETGEAR Support
It is anybody's guess as to how it works or which Netgear model it is based on.
The only suggestion I can think of is that you get the manual for one of Netgear's own DSL modems, perhaps one that looks similar, and see if that gives any clues.
DSL Modems | DSL Routers | NETGEAR
If there is a WAN (Internet) port on the back, then there is a chance that it will work in router mode. Some models have a LAN port that doubles as a WAN port. Only a manual will tell.
The page I posted earlier lists everything that Netgear makes. Perhaps one of them will work with a separate router.
- JC5000Apr 01, 2020Aspirant
Thanks again for the information. I looked and it seems that Netgear is supposed to be coming out with the all-in-one device that I thought might be already available some time this month (Orbi 4G LTE Tri-band WiFi Router (LBR20)). So it looks like I will need two devices: the LB2120 4G LTE modem and a router such as the Netgear R6400. I assume that I can pair these together and connect all of my devices through the router.
- michaelkenwardApr 02, 2020Guru - Experienced User
I am not familiar with that arrangement – I passed up on invitations to test those modems – so I will defer to others on that topic.
The manual for the LB2120 does say that it has
"One yellow RJ-45 Gigabit Ethernet LAN port to connect a router, WiFi router, Ethernet switch or hub, or single computer."
There's even a WAN port for your DSL modem, although what the LB2120 does in that arrangement isn't clear to me.
So seems safe to assume that it will work as you say. But as I said earlier this isn't the right place for informed feedback on portable modems.
For tales of possible woe, try the appropriate section:
