JC5000
Mar 31, 2020Aspirant
Unlocked 4G LTE wifi modem/router that accepts a SIM card
I would like to set up a home network with access to the internet via cell phone provider network. My provider said that I would need an unlocked device that accepts a SIM card to be used on a 4G LTE...
JC5000
Apr 01, 2020Aspirant
Thanks for pointing me in the direction of the LTE modems. I looked at the Netgear LB2120 Modem. If I interpret this correctly, I can connect to it directly through the LAN port or I must purchase some other device to provide WiFi, which is what I need. I have a Netgear ADSL Model 7550 modem/router that I currently use. However, the goal is to eliminate the DSL service and use the wireless to connect to the internet. Is there a mechanism to connect the LB2120 to the Model 7550 and use the router and WiFi capabilities of the 7550 without the DSL service? The 7550 only has 4 LAN ports and a port for the DSL cable. If the 7550 is not compatible, what is the other device that must be purchased? Are there any 4G LTE modem/router/WiFi devices?
michaelkenward
Apr 01, 2020Guru - Experienced User
Netgear may have made it, but the 7550 is specific to AT&T.
No NETGEAR support for the AT&T 7550 DSL Modem Router | Answer | NETGEAR Support
It is anybody's guess as to how it works or which Netgear model it is based on.
The only suggestion I can think of is that you get the manual for one of Netgear's own DSL modems, perhaps one that looks similar, and see if that gives any clues.
DSL Modems | DSL Routers | NETGEAR
If there is a WAN (Internet) port on the back, then there is a chance that it will work in router mode. Some models have a LAN port that doubles as a WAN port. Only a manual will tell.
The page I posted earlier lists everything that Netgear makes. Perhaps one of them will work with a separate router.
