gibby101's avatar
gibby101
Follower
Oct 05, 2019
Using A7000 with raspberry pi 4.
Hi
I have a spare A7000 and would like to use it with my media streamer which is a raspberry pi 4 running Kodi. I plugged it and it sees the USB device but it doesnt seem to recognize it as a wifi adapter.
Thanks!
Steve
1 Reply
  • schumaku's avatar
    schumaku
    Some information to start with is shown here https://wikidevi.com/wiki/Netgear_A7000 - as this site will disappear soon:
    The Edimax driver EW-7833UAC_Linux_Driver_4.3.21 linked to on the right works with Ubuntu 16.04 Kernel 4.4.0-116 if you add the Netgear device ID.
    Add the line {USB_DEVICE(0x0846, 0x9054),.driver_info = RTL8814A}, /* Netgear - A7000 */ to the CONFIG_RTL8814A section in <driver source folder>/os_dep/linux/usb_intf.c.
    It's line 213 in the version mentioned above.
    Then make, and sudo make install as described in the readme.
    You need an ARM driver for your Pi btw.
