CoVIFraud19
Feb 02, 2021Aspirant
WG111 Transmit Power Configuration
Is there some way to configure this device to reduce the Transmit Power? I have no need to be transmitting at max power as my router is well within range. Unlike other devices there is no option for...
michaelkenward
Feb 03, 2021Guru - Experienced User
The WG111v2 may be involved in two way wifi, but it is essentially a wifi receiver.
I'm curious, do you have any reason to believe that your USB adapter is broadcasting too much power? I wouldn't know how to begin to measure it.
