JoshRSpprt
Mar 01, 2023Tutor
What are the most optimal properties for the A7000?
Wanting to optimize the settings for my A7000, I've tried looking up ideal adapter properties online, but most resources I've found either don't list the options I can see, or only mention adapters f...
Mar 01, 2023Guru - Experienced User
For the most part, the defaults tend to work the best with windows.
What actual speeds are you getting over 2.4ghz and 5ghz?
Also keep in mind that speeds over 5ghz drop off quickly with distance/obstructions
- JoshRSpprtMar 01, 2023Tutor
Wi-Fi Network we have setup is 5ghz, according to what it says on the Network and Sharing Center, the speed is around 1.3 Gbps.
As for distance/obstructions, there's not really much I can do about that. I am basically upstairs from the router, but thankfully the router is only in the room directly below me, don't know if that's going to interfere with it too much.- plemansMar 01, 2023Guru - Experienced User
Are you having problems with it?
Or why are you searching for optimal settings?
If you're connecting with a 1.3gig link speed, thats as good as its going to get as its a dual band device (1.3gig over 5ghz, 600mbps over 2.4ghz)- JoshRSpprtMar 01, 2023Tutor
I see, well if that's as good as it's going to get, I suppose there's not much to be done.
But to answer as to why I'm trying to tweak the properties, aside from just trying to see what I can do to improve/optimize my connection, occasionally I suffer from high ping when playing games, it sometimes has a habit of coming and going, and to date I've never figured out a concrete way of solving or relieving the issue.
I know the obvious answer is just to run an ethernet cable, problem is being able to run a cable from downstairs.
