JoshRSpprt
Mar 01, 2023Tutor
What are the most optimal properties for the A7000?
Wanting to optimize the settings for my A7000, I've tried looking up ideal adapter properties online, but most resources I've found either don't list the options I can see, or only mention adapters f...
Mar 01, 2023Guru - Experienced User
Are you having problems with it?
Or why are you searching for optimal settings?
If you're connecting with a 1.3gig link speed, thats as good as its going to get as its a dual band device (1.3gig over 5ghz, 600mbps over 2.4ghz)
JoshRSpprt
Mar 01, 2023Tutor
I see, well if that's as good as it's going to get, I suppose there's not much to be done.
But to answer as to why I'm trying to tweak the properties, aside from just trying to see what I can do to improve/optimize my connection, occasionally I suffer from high ping when playing games, it sometimes has a habit of coming and going, and to date I've never figured out a concrete way of solving or relieving the issue.
I know the obvious answer is just to run an ethernet cable, problem is being able to run a cable from downstairs.
- plemansMar 01, 2023Guru - Experienced User
wifi is susceptible to interference which is why hardwired is always preferred for gaming. You can try changing the router's wifi channel its on for 5ghz in case there's something else on those channels you're using
