canad124466
Apr 08, 2022Follower
Why does my Netgear extender keep disconnecting?
Why does my Netgear extender keep disconnecting ?
Details are key and you gave us none.
1. what extender do you have?
2. what firmware is on it?
3. what router is it connected to?
4. how frequently is it happening?
5. how big is your home and what are the internal walls made from?
6. how far from the router is it and what walls are in the way?
7. did you set it up using wps or using the installation assistant?
Does the A6210|AC1200 High Gain WiFi USB Adapter listed in your footer involved in this in anyway?
Or did you just click the first thing that popped up when you wrote your message?
