PeDaLu
May 15, 2019Initiate
Wi-Fi connection is disconnected regularly.
・ Use in AP mode
・ Firmware: V 1.0.9.64_10.2.64
・ As a phenomenon, all terminals can not be connected at 5 GHz and 2.4 GHz irregularly.
・ Turn off the router and restart it.
・ Used channe...
May 16, 2019Guru - Experienced User
You have a7000 in your name. I take it you mean R7000 as the a7000 is a usb adapter. Plus the firmware listed is for the R7000.
The R7000 .64 firmware has been known to be a bit flaky. For some it works great but for the rest, most are downgrading firmware to an earlier version for better results. I'd recommened the .42 firmware. Here's an older thread that discusses the downgrade.
