Frantelle
Sep 19, 2019Aspirant
Wifi adapter A6100 help
Hi. I bought the a6100 wifi adapter about a year ago which I used, but since moved house and used Ethernet connection, but now need to use the Adapter again. Same PC, I plug in the adapter the genie p...
Frantelle
Thanks for your help mate, I uninstalled and then fresh installed with updated drivers. I can now connect to my internet through the genie. The problem is though my internet settings is saying no internet, secured. Do you know what could be stopping this? I attached a pic to show what I’m getting. Also sorry for the lack of terminology etc I’m kind of out of the loop on these kinds of things.
Frantelle
Won’t let me post picture -.-
- plemansSep 19, 2019Guru - Experienced User
While doing the uninstall try following this procedure:
1. uninstall driver and software
2. unplug the usb device
3. reboot the computer
4. install the driver (and software if you prefer, you can just install the stand alone drive and let windows manage the software if you prefer)
5. plug the usb device in.
Did you do it this route?
If you log into your router (which is what?), does it show on the connected devices page?
All your other devices are still working?
- FrantelleSep 19, 2019AspirantNo I didn’t do it exactly like that, just uninstalled everything inserted the CD and re installed. Shall I do it that way? Also I’m logged in on my router, but can’t find connected devices.. and yes my wifi is working on my phone, PS4 etc.
- FrantelleSep 19, 2019AspirantMy router login is 192.168.0.1
