Frantelle
Sep 19, 2019Aspirant
Wifi adapter A6100 help
Hi. I bought the a6100 wifi adapter about a year ago which I used, but since moved house and used Ethernet connection, but now need to use the Adapter again. Same PC, I plug in the adapter the genie p...
Frantelle
Thanks for your help mate, I uninstalled and then fresh installed with updated drivers. I can now connect to my internet through the genie. The problem is though my internet settings is saying no internet, secured. Do you know what could be stopping this? I attached a pic to show what I’m getting. Also sorry for the lack of terminology etc I’m kind of out of the loop on these kinds of things.
michaelkenward
Sep 20, 2019Guru - Experienced User
Is that in Windows?
My first guess is that you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
