Ollie7600
May 15, 2021Tutor
Wifi extender AC1200 Stopped working after working fine for months
I have tried resetting the router and wifi extender multiple times with both the WPS method and the normal smart wizard method. I’ve tried using static IP as well. The smart wizard acts like it’s set ...
michaelkenward
May 16, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
Ollie7600
May 16, 2021Tutor
I fixed my issue following this thread https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/IP-Configuration-failure-EX6120-Range-Extender/td-p/1114181 even though it was for a different extender it still worked. I had to only pick one band at the start of the smart wizard as picking two doesn't work alot fo the time. One the mywifiext page it now just shows in the diagram of the signals between router and extender. that theres one green signal going into the wifi extender from the router, and theres two green signal coming out.
