Tigerfan77
Apr 21, 2022Initiate
Wifi extender EXT2700 speed
Hi, Wonder if anyone can help I have my Wi-Fi extender connected, speeds and getting a very low in comparison with my normal Wi-Fi. I am getting speeds of 20 MBS with the extender, but I have sp...
Tigerfan77
Ah, so Im stumped with that one`! Thanks for helping!
I did wonder if it wasnt possible, are Powerline wifi adaptors a better bet?
Apr 21, 2022Guru - Experienced User
Powerline adapters are great devices. they don't work well in every home because certain things in home can cause interference. so if you try one, buy it from somewhere with a decent return policy. Speeds also drop a lot when you move from one circuit to the next.
If you're needing to keep your speeds up, a triband has a dedicated backhaul. but they're significantly more expensive.
