SAN925
Jan 09, 2021Aspirant
Wifi stops working after 80%+ GPU usage [Netgear WNA3100M N300]
Netgear WNA3100M N300 Windows 10 Intel UHD 630 graphics and Geforce GT 730 8 gb ram I-7 8700 When ever my GPU usage crosses 80% my wifi stops working! My old wifi usb used to overheat...
michaelkenward
Jan 10, 2021Guru - Experienced User
SAN925 wrote:
I bought a Netgear WNA3100M N300 and now whenever i try to run stuff like obs and anyother app like Blender my wifi stops working.
Smells like something amiss on your PC to me.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Adapters - NETGEAR Communities
I will ask the Netgear moderator to move your message.
- SAN925Jan 10, 2021Aspirant
Hey my bad i didnt mean to choose that router! How ever i have a Digisol router!
- michaelkenwardJan 10, 2021Guru - Experienced User
Digisol routers have nothing to do with Netgear
Your footer says:
WNA3100|Wireless-N 300 USB Adapter
That's not a router. As the label it says it is USB adapter for wifi.
If you don't own one of those, I have no idea what help you expect from this place.
