SAN925
Jan 09, 2021Aspirant
Wifi stops working after 80%+ GPU usage [Netgear WNA3100M N300]
Netgear WNA3100M N300 Windows 10 Intel UHD 630 graphics and Geforce GT 730 8 gb ram I-7 8700 When ever my GPU usage crosses 80% my wifi stops working! My old wifi usb used to overheat...
Jan 12, 2021Guru - Experienced User
have you tried the adapter in other pc/laptops?
If you've isolated it to when the gpu is hitting >80% (probably a bit of strain on cpu as well), it could be a power issue.
Have you checked the power supply?
