Sallygood25
Sep 09, 2025Follower
Windows cannot load the driver for this device
I've recently replaced my onboard wifi/bluetooth adapter (on a HP 14s-dq0xxx with Windows 11) with an BE6500 WiFi Adapter (A9000). I've installed the driver from the latest driver which has installed...
Sep 10, 2025Guru - Experienced User
I've looked at the spec sheet and the manual and can't find that it supports bluetooth. I have one and plugged in and checked to and it doesn't seem to support bluetooth.
and dongknows review spec sheet states no bluetooth.
So zero bluetooth
