billpcape
Jul 18, 2021Follower
wireless A6100 does not on boot up
Windows 10. The A6100 does not work when I boot up the computer. I need to reinstall the Netgeat software from the DC each time I start the computer
What actual pc is it?
Have you tried a different usb port? Maybe its having issues not detecting the usb device or isn't supplying enough power on bootup.
have you tried the wireless adapter in other pc's?
If it doesn't work when you unplug and reinsert the adapter, then I'd investigate your PC.
Check the PC maker for updates drivers to your motherboard. Windows Update will not find those.
As it is, you don't provide much information to go on.
Take this bit:
What do you mean by "does not work"? That could describe various different issues.
Do you mean that the PC does not see the USB adapter?
Or is it a case of Windows not connecting to the wifi?
