Timb99
Jul 05, 2022Aspirant
Wireless ac adapter not connecting to wifi
So I unplugged all the cords to my computer to move it. When I plugged everything back in, my ac adapter for wifi no longer will connect to the wifi at my house. I put in the password but it says it's...
Jul 05, 2022Guru - Experienced User
What wifi adapter do you have?
Does it work in other computers if you try it?
have you uninstalled the wifi adapters driver and reinstalled it?
Or went into windows/mac and "forgotten" the network?
Timb99
I have a A6120 wireless adapter. Comes with a base to stand on. I can't try it on another computer as I only have the one. I have uninstalled and reinstalled the software and nothing happened.
- plemansJul 05, 2022Guru - Experienced User
Not just the software but the driver?
did you try other usb ports?
- michaelkenwardJul 06, 2022Guru - Experienced User
Timb99 wrote:
I have a A6120 wireless adapter. Comes with a base to stand on. I can't try it on another computer as I only have the one. I have uninstalled and reinstalled the software and nothing happened.A6210?
So move the stand? It is, after all, a part of the device that appears to fold up.
As plemans says, try a different port.
If that doesn't work, you may have to go into Device Manager and remove the adapter, including "hidden" entries.
Wifi adapters
But from your description it isn't obvious that the adapter is the problem. If it is the PC that will not connect, maybe that is the problem. As plemans also suggested, tell the PC to forget that it ever saw that SSID. You didn't answer that bit of their message.
