Timb99
Jul 05, 2022Aspirant
Wireless ac adapter not connecting to wifi
So I unplugged all the cords to my computer to move it. When I plugged everything back in, my ac adapter for wifi no longer will connect to the wifi at my house. I put in the password but it says it's...
Timb99
I have a A6120 wireless adapter. Comes with a base to stand on. I can't try it on another computer as I only have the one. I have uninstalled and reinstalled the software and nothing happened.
michaelkenward
Jul 06, 2022Guru - Experienced User
A6210?
So move the stand? It is, after all, a part of the device that appears to fold up.
As plemans says, try a different port.
If that doesn't work, you may have to go into Device Manager and remove the adapter, including "hidden" entries.
Wifi adapters
But from your description it isn't obvious that the adapter is the problem. If it is the PC that will not connect, maybe that is the problem. As plemans also suggested, tell the PC to forget that it ever saw that SSID. You didn't answer that bit of their message.
