barnolde
Mar 14, 2021Follower
Wireless AC Adaptor--AC600 Dual Band
Everytime I cut my computer off--it will not reconnect till I remove software and then reinstall
Mar 15, 2021Guru - Experienced User
What actual adapter do you have?
AC600 is a speed.
- michaelkenwardMar 15, 2021Guru - Experienced User
.... and what do you mean by "cut my computer off"?
