Tj2
Dec 24, 2019Aspirant
Wireless adapter loses connection
Hello, Recently put a PC together and was looking into wireless networking soloutions. I purchased this adapter and plugged in to a USB3.0 port. The adapter randomly disconnects from the internet...
ander999
Jan 12, 2020Aspirant
Am having the same issue. No ones been able to help.
- Tj2Jan 12, 2020Aspirant
I am afraid that after some other changes, nothing helped. I literally went thrugh every option even if it did not make sense and I still had the conneciton issue. I ended up moving things around in the room and running CAT6 to the onboard LAN adapter and problem solved. I took the wireless adapter back for a refund. I usually have good luck with netgear products but this one just was not working.
