RKarim
Nov 17, 2019Aspirant
Wireless Ping Spikes - A7000
Hello, Recently I've started expirencing random ping spikes with my Netgear A7000 adapter. I have reinstalled the software, as well as tried older versions of it to no avail. I have found a solut...
Tom444
Nov 17, 2019Apprentice
To tell the trurth, junk the device. Buy something different.
Write it off as a bad purchase.
I bought it and now only use it as a backup device (since I bought it)
Has never worked from day 1 under Windows 10.
- RKarimNov 17, 2019AspirantWhat would you recommend?
- Tom444Nov 17, 2019Apprentice
If you are something Directional edimax ew-7811dac
Cheap, just works, but they do burn out over the months pushing 100GB's.
I do 400GB per month over about 700 meters, 5G, remote backup nightly.
I was hoping the A7000 would be long lasting, but I'm stocking up on the Edi's. Die/replace/forget until it dies.
At $27 it's way cheaper than I paid for the A7000 and the time to relises this is pointless.
Only have to google A7000 for issues.
8-9 months replacement, not the best thing, but it works for the Edimax.
Plus I'm sure I push it beyond the design spec's, but Netgear has the A7000 that doesn't even work?
So what gives Netgear?
