ElgWnh
Apr 16, 2018Aspirant
Wirless Adapter WNA3100 Compatability
Hello, will my Netgear wireless adapter WAN3100-N300 work with the BT Smart Hub, AC wi-fi technology? I saw an article that mentions, " 802.11ac."
This is a link that gives some information regarding this hub.
http://www.expertreviews.co.uk/bt/bt-smart-hub
I look forward to guidance on this.
Best regards.
I assume you mean WNA3100. (There is no WAN3100.)
No reason why not. The Homehub is just a wifi source.
You might get more detailed help on the BT user forum. Folks there may have more familiarity with the adaptor and the Homehub.
- ElgWnhAspirant
Michael, Many thanks for your prompt reply, much appreciated. I will certainly check on the BT forum. Yes indeed, I meant the, "Netgear adapter WNA3100-N300." Best regards.
